How to retry Upload when connection interrupt with Resume Support?
000O000
Hi. Tried to write a little batch file for winscp:
option batch abort
open ftp://user:pass@100.100.100.100/
cd Backup
cd Server
put d:\SQLBackup\backup.7z.* Backup%TIMESTAMP#yyyymmdd%.7z.* -resumesupport=on
close
It is working, but how can I config to retry the upload if connection was broken? And the resumesupport option seems not to work for me, if I manually start the upload again it will upload from begin without checking which files uploaded correct and skip them.
Re: How to retry Upload when connection interrupt with Resume Support?
It should retry automatically.
If it does not, please attach a full log file showing the problem (using the latest version of WinSCP).
