Topic "How to Sync and Remove using C#"
bman83
I am trying to find an example of removing files after downloading them using C#.
I have looked at the powershell example and cannot seem to get it to work in C#.
Using session.RemoveFiles works - however if files are being added to the source directory during the download they end up being deleted and not downloaded.
Basically I'm looking to mirror what is done in the powershell example shown here:
https://winscp.net/eng/docs/library_example_delete_after_successful_download
Any suggestions would be appreciated.
Brian
Cannot you just do with a simple session.GetFiles(source, target, true) ? Note the remove = true argument.
If not, what particular part of the PowerShell code, do you have problems with, translating to C#?
bman83
Prikryl,
Thanks for the reply - that's exactly what I was looking for.
