Timeout Error
NickB
Timeout Error
Hi
Im very new to winscp im using a c# script task in SSIS to send files to an ftp folder location. this works for another ftp site but for a new one im trying now Im getting a time out.
. 2015-11-04 05:52:39.686 --------------------------------------------------------------------------
. 2015-11-04 05:52:39.686 WinSCP Version 5.5.6 (Build 4746) (OS 6.3.9600 - Windows Server 2012 R2 Standard)
. 2015-11-04 05:52:39.686 Configuration: nul
. 2015-11-04 05:52:39.686 Local account:
. 2015-11-04 05:52:39.686 Working directory: C:\Program Files\WinSCP
. 2015-11-04 05:52:39.686 Process ID: 4920
. 2015-11-04 05:52:39.686 Time zone: Current: GMT-6, Standard: GMT-6 (Central Standard Time), DST: GMT-5 (Central Daylight Time), DST Start: 3/8/2015, DST End: 11/1/2015
. 2015-11-04 05:52:39.686 Login time: Wednesday, November 4, 2015 5:52:39 AM
. 2015-11-04 05:52:39.686 Script: Retrospectively logging previous script records:
> 2015-11-04 05:52:39.686 Script: option batch on
< 2015-11-04 05:52:39.686 Script: batch on
> 2015-11-04 05:52:39.686 Script: option confirm off
< 2015-11-04 05:52:39.686 Script: confirm off
> 2015-11-04 05:52:39.686 Script: open -hostkey="" -timeout=15 sftp://1323279:***@ftp.s4.ee.com:21
. 2015-11-04 05:52:39.686 Session name: 1323279@ftp.s4.ee.com (Ad-Hoc site)
. 2015-11-04 05:52:39.686 Host name: ftp.s4.ee.com (Port: 21)
. 2015-11-04 05:52:39.686 User name: test(Password: Yes, Key file: No)
. 2015-11-04 05:52:39.686 Tunnel: No
. 2015-11-04 05:52:39.686 Transfer Protocol: SFTP
. 2015-11-04 05:52:39.686 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2015-11-04 05:52:39.686 Proxy: none
. 2015-11-04 05:52:39.686 Send buffer: 262144
. 2015-11-04 05:52:39.686 SSH protocol version: 2; Compression: No
. 2015-11-04 05:52:39.686 Bypass authentication: No
. 2015-11-04 05:52:39.686 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2015-11-04 05:52:39.686 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2015-11-04 05:52:39.686 SSH Bugs: A,A,A,A,A,A,A,A,A,A
. 2015-11-04 05:52:39.686 Simple channel: Yes
. 2015-11-04 05:52:39.686 Return code variable: Autodetect; Lookup user groups: A
. 2015-11-04 05:52:39.686 Shell: default
. 2015-11-04 05:52:39.686 EOL: 0, UTF: 2
. 2015-11-04 05:52:39.686 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2015-11-04 05:52:39.686 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2015-11-04 05:52:39.686 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2015-11-04 05:52:39.686 Cache directory changes: Yes, Permanent: Yes
. 2015-11-04 05:52:39.686 DST mode: 1; Timezone offset: 0h 0m
. 2015-11-04 05:52:39.686 Looking up host "ftp.s4.exacttarget.com"
. 2015-11-04 05:52:39.717 Connecting to 66.231.94.106 port 21
. 2015-11-04 05:52:54.842 Waiting for data timed out, asking user what to do.
. 2015-11-04 05:52:54.842 Asking user:
. 2015-11-04 05:52:54.842 **Host is not communicating for 15 seconds.
. 2015-11-04 05:52:54.842 Wait for another 15 seconds?** ()
. 2015-11-04 05:53:56.202 Attempt to close connection due to fatal exception:
* 2015-11-04 05:53:56.202 **Terminated by user.**
. 2015-11-04 05:53:56.202 Closing connection.
. 2015-11-04 05:53:56.202 Sending special code: 12
Re: Timeout Error
You are connecting using an SFTP protocol to the FTP port (21). That's wrong.
Also you should upgrade WinSCP.
