Topic "WinSCP powershell script can't handle swedish characters"
rasmus.hvitfeldt
Hey,
The background:
I want to download files from a SFTP server and the move the downloaded files to another folder on the SFTP server.
What I've done:
I've used the WinSCP powershell module developed by Thomas Malkewitz (https://github.com/dotps1/WinSCP). My script looks like this (I've cut some bits out):
$session = New-WinSCPSession -Credential $Credential -Hostname $server -SshHostKeyFingerprint $SSHKey
Try
foreach ($file in (Get-WinSCPItem $session -Path $RemoteRootFolder -Filter *.xml)) {
Receive-WinSCPItem -WinSCPSession $session -Path $file.Name -Destination $ServerPath
Catch
$ErrorMessage = $_.Exception.Message
Send-MailMessage -From xxxx@xxxx.se -To xxxx.xxxx@xxxx.se -Subject "Couldn't copy remote file!" -Body "The error message was $ErrorMessage" -SmtpServer mail-server.xxxx.se
Try
#Move each file in RemoteRootFolder to RemoteOldFolder
Move-WinSCPItem -WinSCPSession $session -Path $file.Name -Destination $RemoteOldFolder
The error:
The error message was Exception calling "MoveFile" with "2" argument(s): "Error moving file '/xxxx/LEG?RD-151011230000.xml' to 'xxxx/xxxx/LEG?RD-151011230000.xml'."
The "?" character is actally an "Å" letter, which WinSCP can't seem to handle. Any ideas how I can solve this?
I've talked to Thomas and he told me to post here. Smile
rasmus.hvitfeldt
Thank you for your reply.
Here is my attached session log, marked as private.
Session.log (32.66 KB) Private file
Description: (none)
WinSCP handles the file name correctly, imo.
So it must be the server. Maybe it does not support UTF-8.
Try setting raw session settings Utf to "0" (off).
http://winscp.net/eng/docs/rawsettings
Use $RawSetting parameter of New-WinSCPSession.
