Topic ".net Automation with Proxy"
mrmario
Hallo,
I use the following Code Snippet for config the winscp Connection
    With MyConfigSessionOptions
                .Protocol = Protocol.Sftp
                .HostName = MyConfig.HostName
                .UserName = MyConfig.UserName
                .Password = MyConfig.Password
                .SshHostKeyFingerprint = MyConfig.SshHostKeyFingerprintoperty
                .AddRawSettings("ProxyMethod", MyConfig.ProxyMethod)
                .AddRawSettings("ProxyHost", MyConfig.ProxyHost)
                .AddRawSettings("ProxyPort", MyConfig.ProxyPort)
Error: Connection has been unexpectedly closed. Server sent command exit status 0.
I can Connect per GUI.
What can I do?
Thanks!
Please attach a full session log file showing the problem (using the latest version of WinSCP). And also a successful session log file from GUI for comparison.
