Topic "Verifying Checksum - Operation Not Supported"
CptPicard
Hello! I just switched to WinSCP after seeing this post in your documentation about verifying checksums. But I'm having a problem with it. Sad
When I run the custom command, it gets to the "# Calculate remote file checksum" stage, and then returns an error "Operation not supported."
As far as I can tell, I've got everything setup right - is there anything I need to change on the server to make this compatible? Or is there an easy way to swap out the server command to run "sha1sum TARGET" on the shell and return that result?
Thanks for any assistance you can offer!
Additional information:
The server is Ubuntu 14.04, and I'm connected via SFTP. The user in the sessionUrl has full shell access.
I'm using the latest version of both WinSCP and the WinSCP .NET assembly. I've got the script in the same folder as the assembly, I've unblocked the files, and I've edited the script with my session URL. And I've got it in my custom commands of course.
CptPicard
I see that the script didn't work because vsftpd didn't support the checksum protocol. Oh well!
I hacked together a script that works for me on Windows 8 (and an Ubuntu 14.04 server), hopefully it'll help anyone else looking to do the same thing.
https://gist.github.com/Ineluctable/20b370d78ea025ceabd2
Code posted here for posterity:
param (
    # Use Generate URL function to obtain a value for -sessionUrl parameter.
    $sessionUrl = "sftp://user:mypassword;fingerprint=ssh-rsa-xx-xx-xx@example.com/",
    [Parameter(Mandatory)]
    $localPath,
    $remotePath,
    [Switch]
    $pause = $False
try
    Write-Host $localPath -foregroundcolor Gray
    # Calculate local file checksum
    $localChecksum = ((CertUtil -hashfile $localPath SHA1)[1] -replace " ","")
    # Write-Host "Local Checksum:"
    Write-Host $localChecksum
    # Load WinSCP .NET assembly
    Add-Type -Path (Join-Path $PSScriptRoot "WinSCPnet.dll")
    # Setup session options
    try
        # Connect
        Write-Host $remotePath -foregroundcolor Gray
        $sha1Command = "sha1sum -b $remotePath | awk '{print `$1}'"
        $result = $session.ExecuteCommand($sha1Command)
        $result.Check()
        $remoteChecksum = $result.Output;
        # Write-Host "Remote Checksum:"
        Write-Host $remoteChecksum
    finally
        # Disconnect, clean up
        $session.Dispose()
    # Compare cheksums
    if ($localChecksum -eq $remoteChecksum)
        Write-Host
        Write-Host "Match" -foregroundcolor "green"
        $result = 0
    else
        Write-Host
        Write-Host "Does NOT match" -foregroundcolor "red"
        $result = 1
catch [Exception]
    Write-Host $_.Exception.Message
    $result = 1
if ($pause)
exit $result
Thanks for sharing this.
