Topic "Skip zero byte files"
DWVZ2000
We have programs that create numerous files to be transferred to FTP sites. Sometimes some of these files end up with nothing in them, a file size of 0 bytes simply because there is no data for that particular day. When I run WinScp to transfer the files, it transfers all files including the empty files with 0 bytes. We transfer a number of files daily, and the users of the FTP sites I am transferring to don't want me to transfer 0 byte files. Is there a way to only transfer files that have a file size greater than 0 bytes? Basically skip files that have 0 byte size?
David
Use file mask *>0
See http://winscp.net/eng/docs/file_mask
DWVZ2000
prikryl wrote:
Using the size option I either get an error file not found using below :
""put \\Moss\departments\ePremis\MEDASSIST\" & "*%TimeStamp#mmddyyyy%" &
".TXT>1K"" & ""exit"" "
OR using code below it runs but doesn't find the files > 1K
""put \\Moss\departments\ePremis\MEDASSIST\" & "*%TimeStamp#mmddyyyy%" & ".TXT"
& ">1K"" & ""exit"" "
What am I doing wrong?
David
You are missing a space between the put and exit commands.
DWVZ2000
Here's the command I am using AND
I have attached a screen shot of what I get.
I put the space between the "put" and the "exit".
Here is the name of the file I am trying to transfer that is > 1K.
David
Description: Screen shot where winscp doesn't find file > 1K. File name is MEDASSIST_PLC_12032015.TXT
My fault.
I didn't realize it's a mask for a local file, where the size criteria does not work directly.
You have to use -filemask switch:
put \\Moss\departments\ePremis\MEDASSIST\*%TimeStamp#mmddyyyy%.TXT -filemask=>1K
DWVZ2000
prikryl wrote:
My fault.
THANK YOU VERY MUCH. I finally have it working.
