Topic "Unable to gain access into a folder that exists - receiving "Error listing directory" message"
mwarre
For one of our Appservers, WinSCP is unable to change to a shared directory.
Any time a script tries to upload a file to the folder or if I manually try to navigate to the shared folder, I am thrown the below message:
(Intended Directory)
"Error changing directory to"
This is occurring for all directories in a shared path on a particular appserver.
I was able to access this directory a day ago and now WinSCP is saying it is unable to list the directory.
Could someone help with this issue?
Thank you.
