Topic "How to catch errors correctly? server unreachable, fingerprint wrong, access denied, etc."
cakruege
I'm using this powershell code example:
library_powershell#module
I'm trying to differentiate between errors.
For example:
-host unreachable
-fingerprint wrong
-access denied
I replaced Exception with WinSCP.SessionRemoteException
catch [WinSCP.SessionRemoteException]
   Write-Host "WinSCP.SessionRemoteException"
    Write-Host $_.Exception.Message
    exit 1
but every of these 3 failures is a WinSCP.SessionRemoteException. -> didn't help
add failed handler:
function Failed
   param($e)
   $e
$session.add_Failed( { Failed($_) } )
Failed method didn't get called for every of these 3 failures -> didn't help
    finally
        # Disconnect, clean up
        $session.output
        $session.Dispose()
Session.output has the correct information but it's bad parseable text.
Sometimes it is the last line, sometimes not.
What do I do wrong?
The Session.Failed is called all these scenarios.
Indeed the mere $e expression does not yield any output. I do not know why, I do not know PowerShell good enough. But Write-Host $e does.
Anyway, it's the same information as you get from the exception, so it won't help.
The best you can do is to parse Exception message (not log).
cakruege
Thx. You're right.
Hmm, that's not what I wanted to hear Crying or Very sad
I'd like to suggest a new feature:
For example new exceptions types that inherit from SessionRemoteException
HostNotFoundException
WrongFingerprint
AccessDenied
or new Failure2-Event with proper states
That would be my temporary solution
OK, I'll consider that.
