Topic "problem with malformed default setting"
gunnar.kaestle
I've made the mistake to save a default setting with a non-cooperative server.
So, each time I start WinSCP, it automatically tries to connect to the default server and as this is not working at all, the process is aborted.
1) How can I delete these default settings?
2) Shouldn't there be the option for a non-default connection after a failure?
Gunnar
OneChance
You should be able to find those default settings in the Windows registry in the folder:
HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP
Default settings should not be started, they should only be filled as default values on login dialog. Described behaviour is a bug. I'll fix it in next release.
