Topic "How to get and delete files from multiple directories and subdirectories"
rlf
Hi there,
I've got the folllowing directory structure on a FTP server:
/data/
/data/200100/T2251/
/data/200100/T2252/
/data/200200/T3051/
/data/200300/T6051/
In every directory should be pdf files and I didn't know the subdirectory names. Only /data is what I know. I want to get all pdf files and delete them after downloading.
I tried different scripts at least the following script
open sftp://xxx:yyy@server:22
get -delete /data/*.PDF D:\pdf_data\
get -delete /data/2*/*.PDF D:\pdf_data\
get -delete /data/2*/T*/*.PDF D:\pdf_data\
But it didn't work. Can someone help me how to do it correctly?
Thanks in advance
ralf
There's no easy solution for this using WinSCP scripting.
All you can do is using plain get with enabled XML logging. After the download finishes, parse the XML log to find a list of downloaded files and generate delete script for these.
See http://winscp.net/eng/docs/guide_interpreting_xml_log
Though easier is to use PowerShell script with WinSCP .NET assembly.
- Do a regular download = do not set remove parameter of Session.GetFiles to true.
- Iterate TransferOperationResult.Transfers returned by the Session.GetFiles.
- For each successful download of a file, call Session.RemoveFiles.
References:
http://winscp.net/eng/docs/library_session_getfiles
http://winscp.net/eng/docs/library_transferoperationresult
http://winscp.net/eng/docs/library_session_removefiles
