Topic "File name not valid, can you explain what is the issue?"
Philky001
the path is indeed correct. what is not liking here?
-------Program Starts Running----------
-------Session instance successfully Created.----------
All File Paths are downloaded.
Looping for BESTBUYDS
File Path \\SERVER-APP02\ARCUST\IBS\DATA\ORDERS\BESTBYDS\
Error:WinSCP.SessionRemoteException: Error listing directory '\\SERVER-APP02\ARCUST\IBS\DATA\ORDERS\BESTBYDS\'. ---> WinSCP.SessionRemoteException: The filename is not valid.
Error code: 20
Error message from server: Invalid path /\\SERVER-APP02\ARCUST\IBS\DATA\ORDERS\BESTBYDS\
--- End of inner exception stack trace ---
You have the paths wrong somehow.
Either you use local path instead of remote path.
Or the path syntax is wrong. You generally cannot use UNC path syntax for a remote path.
So what is \\SERVER-APP02\ARCUST\IBS\DATA\ORDERS\BESTBYDS\ ? Is it local (or a locally accessible network path) or remote path?
Philky001
Server app02 is our server. But i think the code is calling this remote. ah but before we were successful using a mapped path T:\
but the thing is we get this path from a table so dont have to hard code. I guess i can test using a mapped path to see if that is the cause.
Do you mean that the "app02" is the remote (FTP or SFTP) server?
So why do you use SFTP or FTP, if you can access the files directly over UNC path?
I probably still do not understand, what are you trying to do.
Philky001
app02 is our server where we want to place the orders gotten from ecomm site.
we using SFTP because we were doing manually before and wanted to automate.
OK, so it's a "local path".
That means you have probably swapped "local" and "remote" arguments in some call (probably GetFiles or SynchronizeDirectories).
Show us your code or log file (Session.SessionLogPath), ideally both.
Philky001
this is the program.cs
using System;
using System.Collections.Generic;
using System.Configuration;
using System.Globalization;
using System.IO;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using WinSCP;
namespace SFTPGetConsole
    class Program
        public static int Main()
            try
                Helper.AddtoLogFile("-------Program Starts Running----------");
                // Setup session options
                    Protocol = Protocol.Sftp,
                    HostName = ConfigurationManager.AppSettings["HostName"].ToString(),
                    UserName = ConfigurationManager.AppSettings["UserName"].ToString(),
                    Password = ConfigurationManager.AppSettings["Password"].ToString(),
                    SshHostKeyFingerprint = ConfigurationManager.AppSettings["SshHostKeyFingerprint"].ToString()
                    // Connect
                    session.Open(sessionOptions);
                    Helper.AddtoLogFile("-------Session instance successfully Created.----------");
                    List<vw_importSFTP> ImportFilePaths = DBProvider.Instance.DownloadParameters();
                    Helper.AddtoLogFile("All File Paths are downloaded.");
                    foreach (vw_importSFTP item in ImportFilePaths)
                        if (!string.IsNullOrEmpty(item.FolderName))
                            try
                                Helper.AddtoLogFile("Looping for " + item.gImportID);
                                Helper.AddtoLogFile("File Path " + item.filePath);
                                //RemoteDirectoryInfo directory = session.ListDirectory(ConfigurationManager.AppSettings["RemotePath"].ToString());
                                RemoteDirectoryInfo directory = session.ListDirectory(item.filePath);
                                foreach (RemoteFileInfo fileInfo in directory.Files)
                                    Console.WriteLine("{0} with size {1}, permissions {2} and last modification at {3}",
                                        fileInfo.Name, fileInfo.Length, fileInfo.FilePermissions, fileInfo.LastWriteTime);
                                    string fileName = fileInfo.Name;
                                    //string remotePath = ConfigurationManager.AppSettings["RemotePath"].ToString() + fileName;
                                    string remotePath = item.filePath + fileName;
                                    string FolderName = "";
                                    if (string.IsNullOrEmpty(item.FolderName))
                                        FolderName = "Others";
                                    if (Directory.Exists(ConfigurationManager.AppSettings["LocalPath"].ToString() + "//" + FolderName))
                                        Directory.CreateDirectory(ConfigurationManager.AppSettings["LocalPath"].ToString() + "//" + FolderName);
                                    //Local Path
                                    string localPath = ConfigurationManager.AppSettings["LocalPath"].ToString() + "//" + FolderName + "//" + fileName;
                                    Helper.AddtoLogFile("Local Path " + localPath);
                                    Console.WriteLine("Local Path " + localPath);
                                    if (session.FileExists(remotePath))
                                        bool download;
                                        if (!File.Exists(localPath))
                                            Console.WriteLine("File {0} exists, local backup {1} does not", remotePath, localPath);
                                            Helper.AddtoLogFile(string.Format("File {0} exists, local backup {1} does not", remotePath, localPath));
                                            download = true;
                                        else
                                            DateTime remoteWriteTime = session.GetFileInfo(remotePath).LastWriteTime;
                                            DateTime localWriteTime = File.GetLastWriteTime(localPath);
                                            if (remoteWriteTime > localWriteTime)
                                                Console.WriteLine(
                                                    "File {0} as well as local backup {1} exist, " +
                                                    "but remote file is newer ({2}) than local backup ({3})",
                                                    remotePath, localPath, remoteWriteTime, localWriteTime);
                                                download = true;
                                            else
                                                Console.WriteLine(
                                                    "but remote file is not newer ({2}) than local backup ({3})",
                                                download = false;
                                        if (download)
                                            // Download the file and throw on any error
                                            session.GetFiles(remotePath, localPath).Check();
                                            Console.WriteLine("Download to backup done.");
                                            Helper.AddtoLogFile("Download to backup done.");
                                    else
                                        Console.WriteLine("File {0} does not exist yet", remotePath);
                            catch (Exception ex) { Helper.AddtoLogFile("Error:" + ex.ToString()); }
Philky001
this is the log i have
Error code: 20
at WinSCP.SessionLogReader.Read(LogReadFlags flags)
at WinSCP.ElementLogReader.Read(LogReadFlags flags)
at WinSCP.SessionElementLogReader.Read(LogReadFlags flags)
at WinSCP.CustomLogReader.TryWaitForNonEmptyElement(String localName, LogReadFlags flags)
at WinSCP.CustomLogReader.WaitForNonEmptyElement(String localName, LogReadFlags flags)
at WinSCP.CustomLogReader.WaitForNonEmptyElementAndCreateLogReader(String localName, LogReadFlags flags)
at WinSCP.Session.ListDirectory(String path)
at SFTPGetConsole.Program.Main() in \\fs1\userdata\philk\My Documents\SFTP1\SFTPGetConsole\SFTPGetConsole\Program.cs:line 46
Looping for Walmart.com
You must have a local path (the \\SERVER-APP02\ARCUST\...) in [ConfigurationManager.AppSettings["RemotePath"].
So this call fails:
Philky001
OK thanks we had a dummy thing there. the thing is, the local path is not fixed. it will depend on the customer. All the other values we have in app settings are fixed.
<add key="LocalPath" value="E:\SFTP_FILES\" />
like for walmart it will be \\acust02\walmart
for best buy it will be \\arcust02\bestbuy
so do we need it must be a fixed spot say \\arcust\orders
then we need to parse in a separate process?
I wrote about RemotePath, you respond with a comment on LocalPath. I'm getting lost.
