Topic "synchronize is not deleting web Logs from SFTP Server"
kdyer
Have a server environment that does not have log storage. So, we SFTP web logs to the SFTP server and then pull them from the SFTP server.. The "to the SFTP" works great.
The "from the SFTP" is in question.
Here the script portion in question:
option batch abort
open login@1.1.1.1
# binary
synchronize local -delete "/home/login/client/01/*.*" "D:\Program Files\Logs\ClientServer01\"
synchronize local -delete "/home/login/client/01/subfolder/*.*" "D:\Program Files\Logs\ClientServer01\subfolder\"
synchronize local -delete "/home/login/client/01/tomcat/*.*" "D:\Program Files\Logs\ClientServer01\tomcat\"
so basically the process never moves (or even copies) the files from the SFTP Server to the log store.
Thanks!
I think I have a way to get around this and seems to work. Here is how I modified the script:
option batch abort
open login@1.1.1.1
binary
get -delete  "/home/login/client/subfolder/*.*" "D:\Program Files\Logs\ClientServer01\subfolder\"
Thanks!
The synchronize commands takes a local path as the first argument and a remote file as the second.
See http://winscp.net/eng/docs/scriptcommand_synchronize
You have them the other way around.
Anyway, the synchronize -delete probably does not do what you want.
Your solution with get -delete is probably correct. Though your requirement is quite vague, so I'm not really sure what you want to do.
kdyer
I figured this out.
The
Quote:
get -delete
did work.
We placed the main hourly log archive files into a "root" location which removed extra folders. Created a folder called files and the get -delete won't delete the extra folders.
