Topic "Command line returns connection timed out"
southwick13
I'm unable to connect to an sftp site using the command line. the gui connects successfully. Using the command line it returns Connection timed out.
I'm using windows server 2012r2
WinScp 5.7.5(build 5665)
Invoked with this command - WinSCP.com /script=secureftp.txt
Attached
Script - secureftp.txt
failed command line log - commandline.log
successful gui log - sftp.log
Thanks!
sftp.log (1.95 MB) [Download]
Description: (none)
secureftp.txt (594 Bytes) [Download]
Description: (none)
commandline.log (4.54 KB) [Download]
Description: (none)
In GUI, you connect to non-standard port 8080. While in scripting you connect to the default port 22.
Use open sftp://pjm:***@transfer.grid.alstom.com:8080/download/
See http://winscp.net/eng/docs/session_url
thanks - tried using the above with the port number, and it still did not work.
Any other ideas?
Please post a new log showing that.
I was able to resolve this, thanks!
