Topic "Using WinSCP to insert a LS lookup into a SQL temp table"
lairdmcbride2
The below command works . .we think . . but the table does not get fed.
select @cmd = '"C:\Program Files (x86)\WinSCP\WinSCP.exe" /script=' + @workdir + @workfilename
create table #a (id int identity(1,1), s varchar(1000))
insert #a
exec master..xp_cmdshell @cmd
and in the work file is this. .
open sftp://MyUN:UnHackablePW@sftpSite.basics.net
ls /users/ftpuic/Time/
quit
lairdmcbride2
insert #a
quit
This code works perfectly with the windows internal ftp.exe application. . . but fails with WinSCP . . .my sad. . .
What does the code do? Does it insert a console output of an application to an SQL table?
The winscp.exe is not a console application (like ftp.exe) is). It does not have any output that could be collected. You probably need to use winscp.com.
See http://winscp.net/eng/docs/executables
