Topic "Error condition remote serve file 'in use'"
Philky001
HI I got this error: it seems the file trying to delete was in use. How would you explain this happening, since we only use the batch process now?
Is only explanation that someone was looking at this order at the moment the batch process was running?
Going further, what would you do to code to fix this issue?
Looping for WALMART
File Path \\SERVER-W02\ARCUST\IBS\DATA\ORDERS\WALMART\
File Tranfer successful from /outgoing/orders/WALMART//1277157481.md.neworders to \\SERVER-W02\ARCUST\IBS\DATA\ORDERS\WALMART\1277157481.md.neworders
Error Occurse:WinSCP.SessionRemoteException: Error deleting file '/outgoing/orders/WALMART/1277172050.md.neworders'. ---> WinSCP.SessionRemoteException: Permission denied.
Error code: 3
Error message
from server: Failed to delete file /outgoing/orders/WALMART/1277172050.md.neworders: The process cannot access the file
'\\COMPLETEFTPFS01\sftp_share\sftp_fs\outgoing\orders\WALMART\1277172050.md.neworders' because it is being used by another process.
--- End of inner exception stack trace ---
at WinSCP.OperationResultBase.Check()
at SFTPGetConsole.Program.Main()
Well, we can hardly explain that.
We do not know anything about your server.
Is it happening always, with some files, randomly, ...?
Philky001
it happened one time only for past week. this means that someone was open that file is the only explanation?
Yes, I'd say so.
Philky001
on the scp getfiles - can it have the delete portion put on a slight delay
or something like
session.GetFiles(RemotePath + "/" + fileInfo.Name, LocalPath + fileInfo.Name, ).Check();
// make some time delay for 5 seconds.
// now run to delete
session.GetFiles(RemotePath + "/" + fileInfo.Name, LocalPath + fileInfo.Name, true).Check();
Call the Session.GetFiles without the "remove" flag, wait 5 seconds, and then iterate the list of downloaded files returned by the function, calling Session.RemoveFiles for each.
