Topic "A connection attempt failed because the connected party did not properly respond..."
serm12345
Hi
I have searched the forum for an answer to this error message (but couldn't find much at all):
A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Connection failed.
I am connecting two Windows (Win10 connecting to Win7) laptops using a crossover cable... the pings are successful
I have added an exception to the Windows firewall for Winscp.exe on both laptops
The original error I got was this :
Timeout detected. (control connection)
Connection failed.
But one of the threads in the forum suggested increasing the timeout - which I changed to 60 seconds..
Any ideas???
Here is the log file... but it does not give much away
Thanks!
. 2015-12-14 12:08:27.482 --------------------------------------------------------------------------
. 2015-12-14 12:08:27.483 WinSCP Version 5.7.6 (Build 5874) (OS 10.0.10586 - Windows 10 Home)
. 2015-12-14 12:08:27.483 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
. 2015-12-14 12:08:27.484 Log level: Normal, Logging passwords
. 2015-12-14 12:08:27.484 Local account: RICHARDDELL\Richard
. 2015-12-14 12:08:27.484 Working directory: C:\Program Files (x86)\WinSCP
. 2015-12-14 12:08:27.484 Process ID: 9268
. 2015-12-14 12:08:27.484 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe"
. 2015-12-14 12:08:27.484 Time zone: Current: GMT-5, Standard: GMT-5 (Eastern Standard Time), DST: GMT-4 (Eastern Daylight Time), DST Start: 2015-03-08, DST End: 2015-11-01
. 2015-12-14 12:08:27.485 Login time: December 14, 2015 12:08:27 PM
. 2015-12-14 12:08:27.485 --------------------------------------------------------------------------
. 2015-12-14 12:08:27.485 Session name: XXXXXXXXXXX@192.168.2.3 (Ad-Hoc site)
. 2015-12-14 12:08:27.485 Host name: 192.168.2.3 (Port: 21)
. 2015-12-14 12:08:27.486 User name: XXXXXXXXXXXXX(Password: XXXXXXXXXXXX, Key file: No)
. 2015-12-14 12:08:27.486 Transfer Protocol: FTP
. 2015-12-14 12:08:27.486 Ping type: -, Ping interval: 30 sec; Timeout: 60 sec
. 2015-12-14 12:08:27.486 Disable Nagle: No
. 2015-12-14 12:08:27.486 Proxy: none
. 2015-12-14 12:08:27.486 Send buffer: 262144
. 2015-12-14 12:08:27.486 UTF: 2
. 2015-12-14 12:08:27.486 FTP: FTPS: None; Passive: Yes [Force IP: A]; MLSD: A [List all: A]
. 2015-12-14 12:08:27.486 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2015-12-14 12:08:27.486 Cache directory changes: Yes, Permanent: Yes
. 2015-12-14 12:08:27.486 Timezone offset: 0h 0m
. 2015-12-14 12:08:27.486 --------------------------------------------------------------------------
. 2015-12-14 12:08:27.643 Connecting to 192.168.2.3 ...
. 2015-12-14 12:08:48.494 A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
. 2015-12-14 12:08:48.494 Connection failed.
* 2015-12-14 12:08:48.529 (EFatal) Connection failed.
* 2015-12-14 12:08:48.529 A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
* 2015-12-14 12:08:48.529 Connection failed.
Are you able to connect with any other FTP client? Or even connect to the port anyhow? E.g. using PuTTY.
I'll give that a go and report back
Thanks!
