Topic "File being truncated"
eschind
I followed the http://winscp.net/eng/docs/library#vbnet example for transferring a file using SFTP. For some reason the file is being truncated to 80KB when it is programmatically uploaded to the site. I contacted the vendor whose server we are uploading it to and they said there are not file size limitations in place.
Wondering if anyone has some ideas/suggestions I can test out to try and get the entire file uploaded.
Thanks.
eschind
Good Afternoon, Please see the attached log file using the latest release of WinSCP. Thanks.
log.txt (10.96 KB) [Download]
Description: (none)
There's nothing wrong from WinSCP perspective.
The common problem is that there's not enough space in the file system and the server silently ignores any write attempts.
