Topic "shell commands"
daAgent
Hi there,
I'm new to winscp and would like to use it for a simple script (with the /console and /script options). This is what the script is like:
option batch on
cd /desired/directory
option transfer ascii
put someFiles*
option transfer binary
put anotherfile
close
This works very well, but if I want to execute shell commands I don't get it. What I want is something like:
option batch on
put someFiles*
put anotherfile
tar cf - someFiles* | gzip > someFiles.tgz
close
I found in the forum and some documentation that it is possible to use custom commands but I did not find how to define and how to use them. And I found that things like
cp ! /backup/!`date +%Y%m%d`
should be possible, but again I didn't find the syntax explanation.
I tried
! tar cf - someFiles* | gzip > someFiles.tgz
and
"!" tar cf - someFiles* | gzip > someFiles.tgz
but I always get the error that the command "!" is unknown.
I'm using winscp374.exe (the standalone application download).
Could you please explain the syntax to me and at best give me an example how to use an shell command in such a script.
Many thanks
Command "call" (or "!") is supported since 3.7.5 only.
BTW, you cannot use custom commands in script.
