Topic "Error transferring file"
Arnau Rius
I'm using WinSCP for the first time, because I want to schedule some uploads at night.
The WinSCP used is 5.7.6 (build 5874) running on a Windows Server 2008 R2 (x64).
I've made a bat file to upload those files, but it shows the error: "There's been an error uploading the file 'MyFile'. Abort, Retry, Fail, Fail All: Abort." (I'm translating this from Catalan, I don't know if it's right).
The script I'm using:
open ftp://user:password@server
cd MyDir
option transfer binary
put z:\MyFile.bak
close
And the result is:
Connectant a server ...
Connectat
/MyDir
transfer        binary
confirm         off
z:\MyFile.bak   |            0 B |    0,0 KB/s | binary |   0%
Hi ha un error transferint el fitxer 'z:\A3Common_Calculo.bak'.
A(v)orta, (T)orna-ho a provar, (O)met, O(m)et tot: Avorta
Z: is a network folder. My first try was write the full UNC path, but the GUI refuses to set local folder an UNC path. So, I've tried mapping the shared folder.
The file exists in the remote folder, so I've added the "option confirm off" line in the script. It didn't work either way. I've tried with a file that doesn't exists, but it shows the same error.
What else can it be?
Arnau.
The Windows Scheduler session probably does not see the Z:\ mapping.
While the GUI does not support browsing UNC paths, you can use them in scripting.
Arnau Rius
Well, my tests were made not scheduled, just executing the bat file in a cmd window. Once I get this done, I'll try to schedule with Windows Scheduler.
And I've tried with the UNC path and with the shared folder mapped. None of them worked.
I've been able to upload the file with the GUI, but not with the bat file.
Separately for UNC and mapped drive.
Arnau Rius
Thanks for your answer, but, finally, I'm doing it with Beyond Compare. It has nothing to compare, but it's working.
