Topic "WinSCP.com failure for one file out of several"
ch_icftp
WinSCP version: 5.7.6.5874
I have a script that is pulling 18 files and it hangs on one of the files. I can pull the file using GUI without issue. When I manually run WinSCP.com with the script after about 1mb of transfer the cmd window repeats messages as such:
<filename> : 15504 KB : 177.5 KB/s : binary : -1587610000%
<filename> : 15568 KB : 182.5 KB/s : binary : 100%
<filename> : 15712 KB : 177.5 KB/s : binary : -1608909200%
<filename> : 15776 KB : 183.9 KB/s : binary : 100%
This continues to scroll - and when left for 20 minutes the transfer did not complete - it should only take 6-7 minutes.
Again, other files pull without issue, just this one is failing.
Script is very basic. I can send log and script via email if requested.
Thanks in advance.
Description: Screen of DOS window trying to GET file
ch_icftp
Log file attached
FTP.log (41.15 KB) Private file
Description: (none)
ch_icftp
The file is now pulling without issue. No need to look any farther. I will assume this was an issue on the source side.
