Topic "some advice please"
zen200
This is my first attempt and will be putting this into a windows scheduled task to run nightly.
Will this work ?
Program/script
"C:\Program Files (x86)\WinSCP\WinSCP.exe"
Add Argument:
/command "open ftp://user:password@remoteipaddress/" "synchronize local C:\localfolder /remotefolder" "exit"
Phil
Seems good.
I'd just add /log=c:\path\to\winscp.log to enable logging.
prikryl wrote:
Seems good.
Thanks for the advice.
I haven't managed to get my above setup working for some reason.
I can get the program to open if I remove the argument, nothing happens when I put the argument back in though.
I must be doing something wrong.
This is on a server 2008r2 does that make any difference ?
Thanks for any help.
zen200
So the below does NOT work when put into the windows schedule task.
Program/script:
Add Argument:
So I have turned to testing in the command prompt in windows 2008 r2, and have put the following in.
"C:\Program Files (x86)\WinSCP\WinSCP.exe" ftp://USER:PASSWORD@IPADDRESS/
This is the only way that I have been able to get winscp to open, connect and logged in. but I am unable to get the correct folders to open up automatically and then sync.
Please help, as I have been on this for days now.
[b]This is what I am needing to get working.[/b]
synchronize local C:\OLD SXE DB BACKUP /app/report/db
zen200
This works in command prompt on windows 2008 R2, but not in windows task schedule... Any ideas why ?
"C:\Program Files (x86)\WinSCP\WinSCP.com" /script=c:\scripts\script.txt
[b]SCRIPT FILE CONTENTS[/b]
open ftp://USER:PASSWORD@SERVERIP/
synchronize local C:\LOCALFOLDER /app/report/db
Phil
zen200
New Morning New Start.
So i decided to go out and have a nice drink and meal last night and to let my hair down.
I woke up with a fuzzy head and then sat in front of the pc once again to tackle this seemingly difficult task of getting task manager to work.
I looked at what I had left the settings at yesterday, and couldnt work out what I had done. So I started again from scratch and I got it working first time :shock:
So to clarify this is exactly what I did and hope it helps others.
Put the below into windows task schedule:
[b]Program/script:[/b]
[b]Add Argument:[/b]
/script=c:\scripts\script.txt /log="c:\scripts\logs.log"
Make a script as below and save it in the location c:\scripts\script.txt
[b]script.txt content [/b]
synchronize local C:\LOCALFOLDER REMOTEFOLDER
replace the capitals with your own details.
Thats it i think.
Good luck
Thanks for sharing your solution.
