Topic "Error popup on mouseover event with the custom command buttons bar"
Jocko
If the custom command buttons bar is not anchored (so a floating bar), I got an error message when the mouse is over a button.(see the attached screen capture)
This happens after upgrading winscp (winscp 5.8 beta Build 6030 on a Windows 7)
Note: However the related custom command is run after clicking on the button.
Description: (none)
https://winscp.net/tracker/show_bug.cgi?id=1385
Jocko
Indeed with your latest version (5.8.1 Dev Build 6096), failure messages disappeared on mouseover events with any floating toolbar.
Attached my rnd file
winscp.rar (674 Bytes) Private file
Description: (none)
