Topic "program double directory name in CWD path"
Jokada
I'm having a strange issue when trying to enter a directory in the root folder.
The program connects fine and lists the directories in the root folder. When clicking on one (let's say the directory is named OUT), I get following error:
For some reason WinSCP is looking for a directory in the specified one. Could not retrieve directory listing
/out/out/: No such file or directory
If I choose another directory it will return the same error: /someDir/someDir/ No such file or directory.
I've tested windows FTP command & fileZilla, both are working fine.
Version 567
Tested on Win7, server 2012, both GUI and via Script
Active/passive FTP, same error
Log from script:
. 2016-01-01 22:43:40.889 Command-line: "P:\Development\customer\winscp576\WinSCP.exe" /console=576 /consoleinstance=_6056_500 "/script=EDIscript.txt" "/log=session.log"
. 2016-01-01 22:43:40.889 Time zone: Current: GMT+1, Standard: GMT+1 (Romance (standaardtijd)), DST: GMT+2 (Romance (zomertijd)), DST Start: 27/03/2016, DST End: 30/10/2016
. 2016-01-01 22:43:40.889 Login time: vrijdag 1 januari 2016 22:43:40
. 2016-01-01 22:43:40.889 --------------------------------------------------------------------------
. 2016-01-01 22:43:40.889 Script: Retrospectively logging previous script records:
> 2016-01-01 22:43:40.889 Script: open userxxx@ftphubx
. 2016-01-01 22:43:40.889 Session name: userxxxv@ftphubx(Site)
. 2016-01-01 22:43:40.889 Host name: ftphubx(Port: 21)
. 2016-01-01 22:43:40.889 User name: userxxx (Password: Yes, Key file: No)
. 2016-01-01 22:43:40.889 Transfer Protocol: FTP
. 2016-01-01 22:43:40.889 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2016-01-01 22:43:40.889 Disable Nagle: No
. 2016-01-01 22:43:40.899 Proxy: none
. 2016-01-01 22:43:40.899 Send buffer: 262144
. 2016-01-01 22:43:40.899 UTF: 1
. 2016-01-01 22:43:40.899 FTP: FTPS: None; Passive: Yes [Force IP: A]; MLSD: - [List all: -]
. 2016-01-01 22:43:40.899 Local directory: C:\Users\jo\Documents, Remote directory: /, Update: Yes, Cache: Yes
. 2016-01-01 22:43:40.899 Cache directory changes: Yes, Permanent: Yes
. 2016-01-01 22:43:40.899 Timezone offset: 0h 0m
. 2016-01-01 22:43:40.899 --------------------------------------------------------------------------
. 2016-01-01 22:43:40.909 Connecting to ftphubx. ...
. 2016-01-01 22:43:40.949 Connected with ftphubx. . Waiting for welcome message...
< 2016-01-01 22:43:40.979 220 FTP says hello to unknown@dxxxx.access.be
> 2016-01-01 22:43:40.979 USER userxxx
< 2016-01-01 22:43:40.999 331 Enter password
> 2016-01-01 22:43:40.999 PASS ********
< 2016-01-01 22:43:41.029 230 Good Evening, userxxx.
> 2016-01-01 22:43:41.029 SYST
< 2016-01-01 22:43:41.049 215 UNIX Type: L8
> 2016-01-01 22:43:41.049 FEAT
< 2016-01-01 22:43:41.069 500 Unknown command FEAT
> 2016-01-01 22:43:41.069 OPTS UTF8 ON
< 2016-01-01 22:43:41.089 500 Unknown command OPTS
. 2016-01-01 22:43:41.089 Connected
. 2016-01-01 22:43:41.099 --------------------------------------------------------------------------
. 2016-01-01 22:43:41.099 Using FTP protocol.
. 2016-01-01 22:43:41.099 Doing startup conversation with host.
> 2016-01-01 22:43:41.099 PWD
< 2016-01-01 22:43:41.129 257 "/" is current directory
. 2016-01-01 22:43:41.129 Changing directory to "/".
> 2016-01-01 22:43:41.129 CWD /
< 2016-01-01 22:43:41.149 250 "/" now current directory
. 2016-01-01 22:43:41.149 Getting current directory name.
> 2016-01-01 22:43:41.149 PWD
< 2016-01-01 22:43:41.169 257 "/" is current directory
. 2016-01-01 22:43:41.169 Startup conversation with host finished.
< 2016-01-01 22:43:41.169 Script: Active session: [1] userxxx@ftphubx.
> 2016-01-01 22:43:41.169 Script: cd /out
. 2016-01-01 22:43:41.169 Changing directory to "/out".
> 2016-01-01 22:43:41.169 CWD /out
< 2016-01-01 22:43:41.189 250 "out" now current directory
. 2016-01-01 22:43:41.189 Getting current directory name.
> 2016-01-01 22:43:41.189 PWD
< 2016-01-01 22:43:41.209 257 "out" is current directory
< 2016-01-01 22:43:41.209 Script: out
> 2016-01-01 22:43:41.219 Script: lcd P:\Development\customer\in
< 2016-01-01 22:43:41.219 Script: P:\Development\customer\in
> 2016-01-01 22:43:41.219 Script: get -transfer=binary *.* .\
. 2016-01-01 22:43:41.219 Retrieving directory listing...
> 2016-01-01 22:43:41.219 CWD /out/out/ <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
< 2016-01-01 22:43:41.239 550 /out/out/: No such file or directory <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
. 2016-01-01 22:43:41.239 Could not retrieve directory listing
. 2016-01-01 22:43:41.239 Asking user:
. 2016-01-01 22:43:41.239 Error listing directory 'out'. ("Could not retrieve directory listing","/out/out/: No such file or directory")
< 2016-01-01 22:43:41.239 Script: Error listing directory 'out'.
< 2016-01-01 22:43:41.239 Script: Could not retrieve directory listing
< 2016-01-01 22:43:41.239 /out/out/: No such file or directory
script content:
open userxxxv@ftphubx
cd /out
quit
Thank you for your assistance
Kind regards
Jokada
https://winscp.net/tracker/show_bug.cgi?id=1400
https://winscp.net/tracker/show_bug.cgi?id=1401
