Topic "Problems trying to connect throug vba"
happy
Hi, thank you for reading me. I apologize for my English (I'm Spanish) ... I'll try to do my best Smile
I'm doing some tests to connect to a host using VBA. There's no problem when I do in WinScp interface, but I'm having no success when I try using VBA.
This is the code I'm using:
Sub Conectar()
Dim MySession As New WinSCPnet.Session
Dim MySessionOptions As New WinSCPnet.SessionOptions
    On Error GoTo ErrorHandler
    MySession.SessionLogPath = CurrentProject.Path & "\Log\Log.txt"
    With MySessionOptions
        .Protocol = Protocol_Sftp
        .HostName = "ddddddddd.de.db.com"
        .UserName = "U111111"
        .Password = "MyPass"
        .PortNumber = 22
        .SshHostKeyFingerprint = "ssh-dss 1024 26:b7:f5:fa:0e:0c:71:e6:3a:6e:de:b7:a9:d7:26:41"
        .SshPrivateKeyPath = "C:\Users\U111111\privatekeywinscp.ppk"
    End With
    MySession.Open MySessionOptions
ExitProcedure:
    MySession.dispose
    Set MySessionOptions = Nothing
    Set MySession = Nothing
    Exit Sub
ErrorHandler:
    MsgBox Err.Number & " - " & Err.Description
    GoTo ExitProcedure
End Sub
The error fires in line MySession.Open MySessionOptions and is always the same "Connection has been unexpectedly closed. Server sent command exit status 0."
I asked for logging the "manual" session that executes from winscp interface and also asked for logging the "code" session. The "manual" logging session ends succesfulyy in this way
Prompt (passphrase, "SSH key passphrase", <no instructions>, "Passphrase for key "U111111": ")
Response: "MyPass"
Sent public key signature
Access granted
Opening session as main channel
Opened main channel
Started a shell/command
The "code" logging goes well until
Prompt (3, SSH key passphrase, , Passphrase for key "U111111": )
Disconnected: Unable to authenticate
Any suggestions?
Thanks in advance Smile
Saludos from Barcelona (Spain)
happy
In case it may help, I have to say, in adition of what I exposed, that the Host I want to connect is inside a intranet and for accessing it, is necessary to generate public and private keys using Putty.
Thanks again
For a private key passphrase, use SessionOptions.SshPrivateKeyPassphrase, not SessionOptions.Password.
Note that SessionOptions.SshPrivateKeyPassphrase is deprecated and renamed to SessionOptions.PrivateKeyPassphrase since WinSCP 5.8 beta.
http://winscp.net/eng/docs/library_sessionoptions
happy
That did the trick! Very Happy
Thank you very much!
