Topic "Icons are too small in 4k display"
Benjamin_ZZZ
I have a problem with 4k display, icons are way too small, windows 10 pro 64bit, alienware 15 r2
example:
http://imgur.com/UTRfWW1
This is improved in WinSCP 5.8 beta:
http://winscp.net/tracker/show_bug.cgi?id=1302
Fcojavier
Im working with beta 5.8.1 and same problem.
What can i do?
Thanks!
Can you attach a screenshot of WinSCP?
WinSCP-5.8.3.RC looks small on my 15" 4K screen (the icons, but also the text, which is worse for me). I have set a default 225% zoom, but WinSCP does not apply it, I don't know why since I did not uncheck this option in WinSCP.exe Windows 10 "properties"...
It used to work better I think, and the problem occurred since I connected a 27" screen to my laptop. WinSCP is readable on this 27", but ever since, even when the wider screen is not connected, WinSCP did not revert to the desired scaling on the smaller laptop screen. All other programs do...
The attached screen capture compares the scaling of Windows 10 Explorer, WinSCP and Firefox.
Thank you !
Description: (none)
Does the problem persist computer restart?
