Topic "Bug: Trailing blanks folder names SOLVED"
xmasmc
I am using folders with trailing blanks PC Win7.
Upload to my homepage server works correct.
Synch the folders don't work, because winscp reads folder from the server without trailing blanks and think that the folders are different.
I tried with and without "Replace: '\:*?'
WinSCP Version 5.7.6 (Build 5874)
THANK YOU, problem is solved with Version 5.8 beta
What protocol are you using?
This might be fixed in 5.8 beta:
http://winscp.net/tracker/show_bug.cgi?id=26
xmasmc
Thank you very much, Version 5.8 works correct.
You save a lot of time for me Cool Cool Cool
