Topic "WinScp 5.7.6 can't use saved passwords"
slawomir.pryczek
Hi, i have an issue with winscp, after version 5.5.2 i can no longer use stored passwords.
The password is stored in UI, but it does request the password to be entered on login anyway, sending you both log files so you can compare new version 5.7.6 vs 5.5.2. I attached log from version 5.8 but 5.7.6 works the same. Thanks.
==== 5.5.2 ====
WinSCP Version 5.5.2 (Build 4130) (OS 6.1.7601 Service Pack 1 - Windows 7 Professional)
Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
Local account: slawek\slawo
Working directory: E:\Menu
Process ID: 34776
Command-line: "E:\Menu\WinSCP000.exe"
Time zone: Current: GMT+1, Standard: GMT+1 (Środkowoeuropejski czas stand.), DST: GMT+2 (Środkowoeuropejski czas letni), DST Start: 2016-03-27, DST End: 2016-10-30
Login time: 14 styczeń 2016 16:24:57
Session name: XXXX (Site)
Host name: XXXX (Port: XXXX)
User name: XXXX (Password: Yes, Key file: Yes)
Tunnel: No
Transfer Protocol: SFTP
Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
Proxy: none
Send buffer: 262144
SSH protocol version: 2 only; Compression: Yes
Bypass authentication: No
Try agent: No; Agent forwarding: Yes; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
SSH Bugs: A,A,A,A,A,A,A,A,A,A
Simple channel: Yes
Return code variable: Autodetect; Lookup user groups: A
Shell: default
EOL: 0, UTF: 2
Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
Local directory: Y:\, Remote directory: XXXXXXXXXXX, Update: Yes, Cache: Yes
Cache directory changes: Yes, Permanent: Yes
DST mode: 0; Timezone offset: 0h 0m
Looking up host XXXX
Connecting to XXXX port XXX
We claim version: SSH-2.0-WinSCP_release_5.5.2
Server version: SSH-2.0-OpenSSH_7.1
Using SSH protocol version 2
Server supports delayed compression; will try this later
Using Diffie-Hellman with standard group "group14"
Doing Diffie-Hellman key exchange with hash SHA-1
Verifying host key rsa2 XXXXXXXXXXXXXXXXXXXXXXXX
Host key matches cached key
Host key fingerprint is:
ssh-rsa 2048 62:fc:c8:24:6f:9b:93:3b:ca:81:d9:62:cb:7e:77:d4
Initialised AES-256 SDCTR client->server encryption
Initialised HMAC-SHA-256 client->server MAC algorithm
Initialised AES-256 SDCTR server->client encryption
Initialised HMAC-SHA-256 server->client MAC algorithm
Reading private key file "XXXXXprivate.ppk"
Using username "XXXXXX".
Offered public key
Offer of public key accepted
Authenticating with public key "XXXX@o2.pl"
Prompt (3, SSH key passphrase, , Passphrase for key "XXXX@o2.pl": )
Using remembered password.    <-------- !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Sent public key signature
Access granted
Initiating key re-exchange (enabling delayed compression)
Opening session as main channel
Initialised zlib (RFC1950) compression
Initialised zlib (RFC1950) decompression
Opened main channel
Started a shell/command
==== 5.8 ====
WinSCP Version 5.8 beta (Build 6030) (OS 6.1.7601 Service Pack 1 - Windows 7 Professional)
Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
Log level: Normal, Logging passwords
Process ID: 21724
Command-line: "E:\Menu\WinSCP-8b.exe"
Login time: 14 styczeń 2016 16:22:39
Session name: XXXX (Modified site)
User name: ads (Password: XXXX, Key file: C:\Beano\new-key\private.ppk)
Tunnel: No
Ping type: Off, Ping interval: 30 sec; Timeout: 15 sec
Disable Nagle: No
Proxy: None
Send buffer: 262144
KEX: dh-group1-sha1,dh-group14-sha1,dh-gex-sha1,rsa,WARN
SSH Bugs: Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto
Simple channel: Yes
Return code variable: Autodetect; Lookup user groups: Auto
Shell: default
EOL: LF, UTF: Auto
SFTP Bugs: Auto,Auto
SFTP Server: default
Local directory: Y:\, Remote directory: /home/ads/adserver.adsbackend.com/htdocs, Update: Yes, Cache: Yes
Recycle bin: Delete to: No, Overwritten to: No, Bin path:
DST mode: Win
Connecting to XXXX port XXXX
We claim version: SSH-2.0-WinSCP_release_5.8
We believe remote version has SSH-2 channel request bug
ssh-rsa 2048 XXXXXXXXXX
Reading private key file XXXX\private.ppk"
Using username "XXXX".
Offered public key
Authenticating with public key "xxxx@o2.pl"
Prompt (passphrase, "SSH key passphrase", <no instructions>, "Passphrase for key "xxxx@o2.pl": ")  <------ PROMPT IS DISPLAYED
Response: "XXXX"                                 <------ PASSWORD XXXX ENTERED MANUALLY
Access granted
It was a bug between 5.5 and 5.5.4 that stored password was incorrectly used as a passphrase for a private key file:
http://winscp.net/tracker/show_bug.cgi?id=1176
To provide a passphrase, use -passphrase switch of open command or save the private key unencrypted.
See http://winscp.net/eng/docs/faq_passphrase
