Topic "Winscp Unkown Command"
Good day
please assist my automation scripts have been working fine until I upgraded not sure were the connection is between upgrading and this error, I was running Version 5.5.4 and after upgraded to version Winscp 5.7.5, the scripts run on a schedule and I noticed files were not downloading when I try run the script i.e. double clicking on the bat file , or even copy and paste in windows command prompt, I get the error , Unknown command 'winscp.com' I'm not in any position to downgrade as this is a production server,
regards
Please show us your code and attach a full log file showing the problem (using the latest version of WinSCP).
