Topic "Can't log into an SFTP server where password includes "£"."
jaccort
I am unable to log into an SFTP server where my password contains a "£" symbol.
I think this is a bug, as I'm able to connect using an SFTP command line in Linux just fine.
Reproducible: Always
Testing Methodology:
    Set up a user on an SFTP server with a £ symbol within their password.
    Attempt to connect to this server with the credentials you have just set up.
Version of Windows: 7 Professional
Versions of WinSCP tested: 5.7.6, 5.1.5.
Protocol: SFTP
Method of connection: GUI using Commander interface.
Error (WinSCP):
Access denied.
Error (Server side):
[30] Fri 15Jan16 15:26:26 - (009053) SSH2_MSG_USERAUTH_REQUEST: user: test; service: ssh-connection; type: password
[02] Fri 15Jan16 15:26:26 - (009053) Invalid login credentials; user: "test"; password: "**********"
[31] Fri 15Jan16 15:26:26 - (009053) SSH2_MSG_USERAUTH_FAILURE: login failed
Please find log file attached.
test@XXXXXX.co.uk.log (8.35 KB) Private file
Description: Log file from failed login attempt
Matus
I have the same problem.
Thanks for your reports.
This should be resolved in WinSCP 5.8 beta:
http://winscp.net/tracker/show_bug.cgi?id=1014
