Topic "Unable to upload to FTP site with batch file"
I'm trying to upload a file using a batch file and WinSCP 5.7.6.
I can connect to the server and the file is uploaded. WinSCP then says the upload failed, and asks me whether I want to abort or retry.
I've tried it usign the GUI and get the same result.
Can I stop WinSCP asking me to retry or fix the error altogether?
Below is the log from the GUI.
Connecting to www.site.com ...
Connected with www.site.com. Waiting for welcome message...
220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
220-You are user number 5 of 50 allowed.
220-Local time is now 12:28. Server port: 21.
220-This is a private system - No anonymous login
220-IPv6 connections are also welcome on this server.
220 You will be disconnected after 15 minutes of inactivity.
USER user@site.com
331 User user@site.com OK. Password required
PASS **********
230-Your bandwidth usage is restricted
230-OK. Current restricted directory is /
230 2264 Kbytes used (11%) - authorized: 20480 Kb
SYST
215 XXXXXXXXXXXXX
FEAT
211-Extensions supported:
 EPRT
 IDLE
 MDTM
 SIZE
 MFMT
 REST STREAM
 MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
 MLSD
 AUTH TLS
 PBSZ
 PROT
 TVFS
 ESTA
 PASV
 EPSV
 SPSV
 ESTP
211 End.
Connected
Doing startup conversation with host.
PWD
257 "/" is your current location
Changing directory to "/".
CWD /
250 OK. Current directory is /
Getting current directory name.
PWD
Startup conversation with host finished.
File: 'C:\AccpacData\Data\Scheduled_Reports\Airland\Airland_CSV.csv' [2016-01-18T00:00:32.808Z] [496]
Copying "C:\AccpacData\Data\Scheduled_Reports\Airland\Airland_CSV.csv" to remote directory started.
Binary transfer mode selected.
Starting upload of C:\AccpacData\Data\Scheduled_Reports\Airland\Airland_CSV.csv
TYPE A
200 TYPE is now ASCII
PASV
227 Entering Passive Mode (203,117,178,74,120,60)
MLSD
150 Accepted data connection
226-Options: -a -l
226 8 matches total
type=cdir;sizd=4096;modify=20160118032729;UNIX.mode=0755;UNIX.uid=866;UNIX.gid=866;unique=903g17603b; .
type=pdir;sizd=4096;modify=20160118032729;UNIX.mode=0755;UNIX.uid=866;UNIX.gid=866;unique=903g17603b; ..
type=file;size=10;modify=20160118042822;UNIX.mode=0600;UNIX.uid=866;UNIX.gid=866;unique=903g1764ed; .ftpquota
type=file;size=496;modify=20160118042822;UNIX.mode=0644;UNIX.uid=866;UNIX.gid=866;unique=903g176c0e; Airland_CSV.csv
type=file;size=8116;modify=20160118025908;UNIX.mode=0644;UNIX.uid=866;UNIX.gid=866;unique=903g176c1e; Airland_CSV2.csv
type=file;size=875520;modify=20160118040211;UNIX.mode=0644;UNIX.uid=866;UNIX.gid=866;unique=903g2cee005; Airland_Import.xls
type=file;size=1434857;modify=20160118040211;UNIX.mode=0644;UNIX.uid=866;UNIX.gid=866;unique=903g176537; Airland_Import.xml
type=dir;sizd=4096;modify=20150323031452;UNIX.mode=0755;UNIX.uid=866;UNIX.gid=866;unique=903g176a50; System Volume Information
TYPE I
200 TYPE is now 8-bit binary
PASV
227 Entering Passive Mode (203,117,178,74,117,77)
STOR Airland_CSV.csv
226-2264 Kbytes used (11%) - authorized: 20480 Kb
226-File successfully transferred
226 0.053 seconds (measured here), 9.14 Kbytes per second
MFMT 20160118000032 Airland_CSV.csv
Disconnected from server
Connection was lost, asking what to do.
Asking user:
Lost connection. ("Disconnected from server","Copying files to remote side failed.")
(ESshFatal) **Lost connection.**
The server seems to disconnect the session on MFMT command (used to update a timestamp of the uploaded file).
No idea why, you should consult server administrator.
Or use -nopreservetime switch to disable updating a timestamp of the uploaded file.
Thank you.
That seems to have done the trick.
