Topic "Timeout waiting for external console to complete the command"
filipd
Hello
I have a PS script (using WinSCP .NET assembly) to synchronize a directory between Windows (target) and Linux (source).
Most of the time, the script fails with the following error message :
2016-01-17 23:27:08.238 Type: SSH_FXP_CLOSE, Size: 13, Number: 236635908
* 2016-01-17 23:27:08.613 (ECommand) **Copying files from remote side failed.**
* 2016-01-17 23:27:08.613 Timeout waiting for external console to complete the command.
< 2016-01-17 23:27:08.613 Script: Copying files from remote side failed.
< 2016-01-17 23:27:08.676 Script: Timeout waiting for external console to complete the command.
. 2016-01-17 23:27:08.769 Script: Failed
> 2016-01-17 23:27:19.551 Script: exit
. 2016-01-17 23:27:19.566 Script: Exit code: 1
. 2016-01-17 23:27:19.566 Closing connection.
. 2016-01-17 23:27:19.629 Sending special code: 12
. 2016-01-17 23:27:19.629 Sent EOF message
The logfile can be found in attachment.
Thanks for helping me out
Filip
copy.zip (866.37 KB) Private file
Description: file compressed using 7-zip
Can you please try the latest version first?
filipd
ok, we'll do.
I'll keep you informed (job only runs during the night)
filipd
Hello
Job failed again last night.
New log to be found in attachment.
Br
Filip
copy20160119.log (892.64 KB) Private file
Description: (none)
Why do you have the timeout set to 0? That does not make any sense.
filipd
Timeout set to 0 ?
I've lost you there : the code looks as follows :
try
# Load WinSCP .NET assembly
Add-Type -Path "C:\Program Files (x86)\WINSCP\WinSCPnet.dll"
# Setup session options
$sessionOptions.Protocol = [WinSCP.Protocol]::Sftp
$sessionOptions.HostName = "XXXXXXX"
$sessionOptions.UserName = "XXXXXXX"
$sessionOptions.Password = "XXXXXXX"
$sessionOptions.Timeout = 300
$sessionOptions.SshHostKeyFingerprint = "ssh-rsa XXXXXX"
try
# Connect
$session.ExecutablePath = "C:\Program Files (x86)\WINSCP\winscp.exe"
$Session.SessionLogPath = "C:\Scripts\copy.log"
# $Session.DebugLogPath = "C:\Scripts\copydebug.log"
# Synchronize files
$transferOptions.TransferMode = [WinSCP.TransferMode]::Binary
$transferOptions.SpeedLimit = 6000
$transferResult_Data = $session.SynchronizeDirectories([WinSCP.SynchronizationMode]::Local, "E:\PRD_BACKUPS\DATA\", "/hana/hana-backup/PRD/data/",$true,$false,[WinSCP.SynchronizationCriteria]::Time,$transferOptions)
$transferResult_Data.Check()
$transferResult_Logs = $session.SynchronizeDirectories([WinSCP.SynchronizationMode]::Local, "E:\PRD_BACKUPS\LOGS\", "/hana/hana-backup/PRD/log/",$true,$false,[WinSCP.SynchronizationCriteria]::Time,$transferOptions)
$transferResult_Logs.Check()
finally
# Disconnect, clean up
$session.Dispose()
Send-MailMessage -From "hostname" -To "XXXXXXXXX" -Subject "synchronization of backupfiles (DATA & LOGS) from <hostname> to <hostname> finished OK" -SmtpServer "yyy"
exit 0
catch [Exception]
$ErrorMessage = $_.Exception.Message
Send-MailMessage -From "hostname" -To "XXXXXXXXX" -Subject "synchronization of backupfiles (DATA or LOGS) from <hostname> to <hostname> FAILED !" -SmtpServer "yyy" -Body "Error message is $ErrorMessage"
exit 1
The SessionOptions.Timeout is of type TimeSpan.
The 300 gets converted by PowerShell to TimeSpan 00:00:00.0000300 what rounds to zero later.
filipd
thanks, my mistake.
I'll adjust this timeout parameter and try the job again
