Topic "Problems Running Script"
jchornsey
I'm trying to execute WinSCP with a script from within PowerShell. I've created the PS script so that it creates the WinSCP script file programmatically based on yesterday's date.
The script file is created successfully and when I execute those steps from within "winscp.exe /console" or "winscp.com", each of the steps work perfectly.
However, when I try to execute from a command line with the "/script" switch, either nothing appears to happen, or I get an error.
Nothing is generated with the "/log" switch.
c:\Program Files (x86)\WinSCP>winscp.exe /console /script="I:\scripts\2016-01-21.txt" /log="I:\log.txt"
c:\Program Files (x86)\WinSCP>winscp.com /console /script="I:\scripts\2016-01-21.txt" /log="I:\log.txt"
No mapping for the Unicode character exists in the target multi-byte code page
c:\Program Files (x86)\WinSCP>winscp.com /script="I:\scripts\2016-01-21.txt" /log="I:\log.txt"
c:\Program Files (x86)\WinSCP>winscp /script="I:\scripts\2016-01-21.txt" /log="I:\log.txt"
c:\Program Files (x86)\WinSCP>winscp.exe /script="I:\scripts\2016-01-21.txt" /log="I:\log.txt"
c:\Program Files (x86)\WinSCP>winscp /script=I:\scripts\2016-01-21.txt /log=I:\log.txt
Any ideas?
What happens when you run the same commands in Windows command-line (cmd.exe)?
jchornsey
The "code" section is from the command prompt.
If I run the script command from within 'winscp.exe /console' or 'winscp.com', each of the commands in the script run fine.
When I try to execute with the '/script' switch, nothing happens. Or, I get the unicode mapping error.
I've never seen that "Unicode" error before.
What happens when you use winscp.exe /console /script=...? Does console window popup?
jchornsey
It does, but it disappears so quickly, I can't see if it actually did anything.
And, with the /log switch, nothing is logged.
Are you sure you have a write access to that I: drive? Could you try to log to a local drive instead (like %TEMP%)?
What happens when you use winscp.com from Start > Run instead of a cmd.exe console/command-line?
What happens when you use winscp.com from console/command-line and redirect its output to a local file?
jchornsey
Thanks for your comments and suggestions. Unfortunately, I wasn't able to get past the error. So, I just wrote the script to use the built-in Microsoft FTP client.
Thanks, though!
kkas
I'm experiencing same behaviour.
It worked once, after making one line change in script -txt file, got code page mapping error.
put -nopermissions -filemask="*>=1D" *
Used ver 5.7.6. and 5.8.1b
Works ok with winscp.exe /console /script=
C:\Temp>winscp.com /script=C:\temp\upload_script.txt /log=C:\temp\winscp.log /loglevel=0
C:\Temp>"C:\Program Files (x86)\WinSCP\start_script.bat"
C:\Temp>winscp.com /script="C:\Program Files (x86)\WinSCP\upload_script.txt" /log="C:\Program Files (x86)\WinSCP\winscp.log" /loglevel=0
BR,
Kimmo
Can you attach the script file?
Cassu
Here you go, had to remove actual address and key.
All commands are working perfectly with CLI. Starting this with .bat and task scheduler bugs..
open scp://xxxx@1.2.3.4 / -hostkey="ssh-rsa 2048 key" -privatekey="C:\Program Files (x86)\WinSCP\hostname_private_ssh_key_wo_pass" -rawsettings AgentFwd=1
# Change local directory
lcd z:\
# Force ascii mode transfer
option transfer ascii
# command
pwd
# command
ls
# put 24h modifioidut -nopermissions
pwd
ls
BR,
Kimmo
The script looks good. Though I really mean, if you can attach it as a file?
What was the one line change you did?
MarcoFR73
Hi all.
I had same problem.
The file script was wrote under Windows, but the server witch I was wanting to access is an Unix server.
Finally, I rewrote the script under Unix, with vi.
And that's fine.
ps : sorry for my bad english...
