Topic "throws me out when I delete local files"
leroy
I am using latest WinSCP with Norton interface. When I delete a local file using the interface, WinSCP throws me into the editor. The file is deleted, but I have to reopen the WinSCP window.
I asked a coworker to try it on his machine and he has the same problem.
How do I stop this from occurring?
Into what editor? How do you delete the file?
leroy
The problem persists. If I right-click and delete a file, I am thrown out od Win SCP and into EditPlus, the external editor I have designated. It does not happen if I select multiple files for deteting.
I guess you delete local file, do you? What version of Windows are you using? The proble you describe happens occasionaly on older versions of Windows. Note that the deletion is not done by WinSCP, but by Windows Explorer (the right click menu on local file is sytem menu not WinSCP menu). I suppose that if you delete the file using WinSCP menu or toolbar this won't happen.
