Topic "Authntication problem for WebDAV on IIS 7.5"
I'm not able to connect to a WebDAV folder on a IIS 7.5 server using TLS/SSL. Here's what I see in the connection window:
Connecting to host
Authenticating...
Authenticating...
Authenticating...
Authenticating...
Authenticating...
Authenticating...
Authenticating...
Authenticating...
Authenticating...
until it hangs and crash. Looks like the same issue in this thread:
http://winscp.net/forum/viewtopic.php?t=15850
I'm using WinSCP 5.7.6. I've enabled logging and the following line appears many times in the logs:
[status-line] < HTTP/1.1 401 Unauthorized
WinSCP don't prompt me for a user name or password even if I leave those fields empty in the Login window as it normally does for a SFTP connection.
I've found out that if I create a local Windows account on my computer using the same user name and password as on the server, WinSCP is working inside this account. It looks like WinSCP is using Windows credentials to connect to a WebDAV folder.
Cheers
Patrick
Thanks for your reply. Here's 2 log files. Please note I've changed the server's host name in the files. One last thing, the WebDAV server is part of an AD domain while my computer isn't. It's always the same no matter what user name/password I put in the WinSCP's login window.
Cheers,
Patrick
Working.log (19.53 KB) [Download]
Description: This log file was generated when I was able to connect. I was logged in a local account who has the same user name and password than my account on the WebDAV server. If I put a different password on my local account, my server's account get locked when I
Authentication problem.log (402.86 KB) [Download]
Description: This log file was generated when the problem occurred. I was logged in the local administrator account which doesn't exist on the WebDAV server.
Thanks for the logs.
pat2855
Mail sent.
http://winscp.net/tracker/show_bug.cgi?id=1397
