Topic "Excel VBA sessionoption object returns Activex cannot create object error"
karthiknsra
I have recently registered the winscpnet.dll using .NET Framework C:\Windows\Microsoft.NET\Framework64\v2.0.50727. And I have added the tlb file generated to my VBA references. But when I try to instantiate sessionoptions object, it throws an error "Activex cannot create object". Not sure what went wrong here. Could you please guide.
Regards
Karthik
karthiknsra
Can someone please help me here as this is really critical at the moment for me
karthiknsra
I just found that I was able to connect using vbscript. And if I use VBA, it is not working. Can anyone suggest the problem.
My answer to your duplicate post on Stack Overflow:
http://stackoverflow.com/q/35091706/850848
Quote:
The Microsoft Excel is 32-bit application, so you probably have to register the WinSCPnet.dll for 32-bit .NET framework, even on 64-bit system.
As the instructions for registering the WinSCP .NET assembly for COM shows, on 64-bit system, you generally need to register the assembly both for 32-bit and 64-bit:
%WINDIR%\Microsoft.NET\Framework\v4.0.30319\RegAsm.exe WinSCPnet.dll /codebase /tlb:WinSCPnet32.tlb
%WINDIR%\Microsoft.NET\Framework64\v4.0.30319\RegAsm.exe WinSCPnet.dll /codebase /tlb:WinSCPnet64.tlb
Do not add the .tbl manually to Excel. The assembly appears itself after being registered correctly.
karthiknsra
Thank you so much. This resolved the problem.
You are welcome. Can you accept my answer on Stack Overflow to close the question?
