Topic "WinSCP .NET assembly (powershell) putfiles from UNC path only uploads 1 file"
Stan.Gobien
I'm using WinSCP 5.7.6.0 and the 5.7.6.0 WinSCPnet.dll file.
I have looked at the many examples and written my scripts accordingly.
My upload script has the problem that it only uploads 1 file, even if multiple are present. If there are 3 files I would need to run the script 3 times. I have tried both using putfiles as synchronizedirectories with option Remote. Both have the same behaviour wich leads me to believe it my having some to do with me using a UNC path as local folder.
I have played with tranferoptions.filemask, i have added "*.*" to my localpath and remotepath. But this does not make any difference. Only 1 file gets uploaded.
Does anyone see what I'm doing wrong, or is this really a bug?
Below is the script for reference:
#Start
Write-Host ("Start script.")
try
    # Load WinSCP .NET assembly
    Add-Type -Path "c:\program files (x86)\winscp\WinSCPnet.dll"
    # Setup session options
    $sessionOptions.Protocol = [WinSCP.Protocol]::Sftp
    $sessionOptions.HostName = "**********"
    $sessionOptions.PortNumber = 0000
    $sessionOptions.UserName = "**********"
    $sessionOptions.SshPrivateKeyPath = "C:\FTP\******\Private-Key\*******.ppk"
    $sessionOptions.SshHostKeyFingerprint = "ssh-rsa 2048 68:92:****************:15:5e:78"
    Write-Host ("Connecting.")
   # Upload files
    try
        # Connect
      $localPath = "\\SOMESERVER.fqdn\EDI\SOMEFOLDER\TEST\EXPORT\"
        $remotePath = "/TEST/IMPORT/"
      $backupPath = "\\SOMESERVER.fqdn\EDI\SOMEFOLDER\TEST\SAVE\"
       #File list:
      Write-Host ("File list: ")
      #transferoptions
      #$transferOptions = New-Object WinSCP.TransferOptions
        #$transferOptions.FileMask = "*.*"
        # Upload files, collect results
        $transferResult = $session.PutFiles(($localPath + "*.*"), ($remotePath + "*.*"), $False)
        # Iterate over every transfer
        foreach ($transfer in $transferResult.Transfers)
            # Success or error?
            if ($transfer.Error -eq $Null)
                Write-Host ("Upload of {0} succeeded, moving to save" -f
                    $transfer.FileName)
                # Upload succeeded, move source file to backup
                Move-Item $transfer.FileName $backupPath -force
            else
                Write-Host ("Upload of {0} failed: {1}" -f
                    $transfer.FileName, $transfer.Error.Message)
      #End of files:
      Write-Host ("End of files. ")
    finally
        # Disconnect, clean up
        $session.Dispose()
      Write-Host ("Disconnected.")
    exit 0
catch [Exception]
    Write-Host $_.Exception.Message
    exit 1
Thank you!
Stan.Gobien
Thank you for your answer.
because of the session log file i have now seen the error:
15:47:18.770 Status code: 3, Message: 521, Server: This server does not support operations to modify file attributes., Language:
* 2016-02-03 15:47:18.770 (ETerminal) Permission denied.
* 2016-02-03 15:47:18.770 Error code: 3
* 2016-02-03 15:47:18.770 Error message from server: This server does not support operations to modify file attributes.
. 2016-02-03 15:47:18.770 Asking user:
. 2016-02-03 15:47:18.770 **Upload of file '***********.xml' was successful, but error occurred while setting the permissions and/or timestamp.**
. 2016-02-03 15:47:18.770 If the problem persists, turn off setting permissions or preserving timestamp. Alternatively you can turn on 'Ignore permission errors' option. ("Permission denied.
. 2016-02-03 15:47:18.770 Error code: 3
. 2016-02-03 15:47:18.770 Error message from server: This server does not support operations to modify file attributes.")
< 2016-02-03 15:47:18.770 Script: Upload of file '*************.xml' was successful, but error occurred while setting the permissions and/or timestamp.
< 2016-02-03 15:47:18.770 If the problem persists, turn off setting permissions or preserving timestamp. Alternatively you can turn on 'Ignore permission errors' option.
< 2016-02-03 15:47:18.770 Script: Permission denied.
< 2016-02-03 15:47:18.770 Error code: 3
< 2016-02-03 15:47:18.770 Error message from server: This server does not support operations to modify file attributes.
* 2016-02-03 15:47:18.785 (EScpSkipFile) **Upload of file '***************.xml' was successful, but error occurred while setting the permissions and/or timestamp.**
* 2016-02-03 15:47:18.785 If the problem persists, turn off setting permissions or preserving timestamp. Alternatively you can turn on 'Ignore permission errors' option.
* 2016-02-03 15:47:18.785 Permission denied.
* 2016-02-03 15:47:18.785 Error code: 3
* 2016-02-03 15:47:18.785 Error message from server: This server does not support operations to modify file attributes.
. 2016-02-03 15:47:18.785 Script: Failed
> 2016-02-03 15:47:19.347 Script: exit
. 2016-02-03 15:47:19.347 Script: Exit code: 1
. 2016-02-03 15:47:19.347 Closing connection.
. 2016-02-03 15:47:19.347 Sending special code: 12
I have amended my script
      #transferoptions
      $transferOptions.FilePermissions = $Null # This is default
      $transferOptions.PreserveTimestamp = $False
        $transferResult = $session.PutFiles(($localPath + "*.*"), ($remotePath + "*.*"), $False, $transferOptions)
Now it works as expected.
Thank you for your time
