Topic "Winscp RemoteFileInfo how to convert the file into byte array in C# .net"
Aditya
I am in trouble over on issue,I have to read a file content or read the file bytes and need to store in it our database.
How to do it in WinScp in .net System.Io.File we can simply call File.ReadAllBytes(file).
How to do it in Winscp RemoteFileInfo.
Sample code .
session.Open(sessionOptions);
if (objFTP.RequestFor == "FR")
//sDirectoryPath.Append(objFTP.ReferenceNo);
directory = session.ListDirectory(basePath+objHCSAuthenticate.Source+"/"+objFTP.ReferenceNo); // Creation winscp Directory
else
//sDirectoryPath.Append(objFTP.PreAuthNo);
directory = session.ListDirectory(basePath + objHCSAuthenticate.Source + "/" + objFTP.PreAuthNo); // Creation winscp Directory
foreach(RemoteFileInfo fileInfo in directory.Files)
string sFileNAme = string.Empty;
string sDocShortCode = string.Empty;
string sDocType = string.Empty;
// sFileNAme = Path.GetFileName(file1);
sFileNAme = fileInfo.Name;
string[] FileNameArray = sFileNAme.ToString().Split('_');
sDocShortCode = FileNameArray[1]; //Get DocumentShortCode
sDocType = GetDocumentType(sDocShortCode);
//byte[] bytes = File.ReadAllBytes(file1);
byte[] bytes =System.Text.Encoding.UTF8.GetBytes(fileInfo.GetHashCode);
My response to your duplicate post on Stack Overflow:
http://stackoverflow.com/q/35312694/850848
Quote:
WinSCP .NET assembly does not support "downloading" remote file contents to memory.
All you can do is to download the file to a local temporary location and read it to the memory from there.
    // Connect
    // Download to a temporary folder
    string localPath = Path.GetTempFileName();
    session.GetFiles(remotePath, localPath).Check();
    // Read the file contents
    byte[] contents = File.ReadAllBytes(localPath);
    // Delete the temporary file
    File.Delete(localPath);
Aditya
Can you more elaborate like how you get the path and all using remote file info
