Topic "Put function without naming file"
prmayer
I'm running the below script but I get an error, "No file matching '*' found." Ultimately, I would like to set the name of the file that will be loaded on the remote directory but nothing is working at this point. I've tried using *.txt and it has not worked either. The file name is 7-digits and can be random but it's always a text file.
put -neweronly -filemask=*>24H C:\ats\Vendor%2%Data\* /home/ftp/files/Data/ATS/Vendor/
Anyone have any advice?
Paul
prmayer
See attached log file.
log160216.txt (7.74 KB) [Download]
Description: (none)
Does the directory really have a name Vendor%2%Data?
The %2% has a special meaning in WinSCP. It's replaced by the second argument of the script. But you do not pass any. Maybe you wanted to?
prmayer
In the examples I found the %2% was used to count for space in a file path. Is there another variable I should use?
prmayer
Got it. Needed to put the file path that has a directory with spaces in it in double quotes.
