Topic "Synchronize problem in script mode"
Marcel
I have not the same effect when I use the synchonize function in GUI or script mode.
I need a synchronize who look to the size and not the timestamp. Since the newest version this is posible now.
When I start the tool in the GUI mode all works correct for me.
But when I start over a script file, I think the synchronize use always the timestamp?
For both test I used the same INI file!
The only difference I found in the log file was the "params":
Synchronizing local directory 'D:\SecureCopy\Local' with remote directory '/incoming', mode = 1, params = 1542
Synchronizing local directory 'd:\SecureCopy\Local' with remote directory '/incoming', mode = 1, params = 2
How can I enforce the same in the script mode?
I'm using version 3.7.5 (build 294).
Thanks for any help.
Regards,
Marcel
That seems like a bug. I'll fix it in the next release.
