Topic "using the find feature to search directories"
i would like to search in a location called /incoming/space/
within this location are approx 200 folders each having the same set of sub folders
example name of folder is A000088800, there are 200 of these with diff names under /incoming/space
example of a sub folder is X12_Trans, each of the 200 folders contains this sub folder
at any given time, from /incoming/virtual, i would like to search for any files located in all of the X12_Trans folders.
how do set the "file mask" and "search in" fields to accomplish this ? thank you john
Actually this used to be possible in the past.
But this change broke it:
I'll consider improving this.
