Topic "Copying files from remote side failed. Failure writing network stream."
dotps1
Contributor
I have a scheduled task that runs during the night and downloads a very large database bak file (around 10GB). And many nights if fails. But when I run the scheduled task (not just run the script) it works fine everytime. Does this error look more like an issue with the remote side FTP server?
WinSCP.SessionRemoteException: Error transferring file '/DatabaseBackupFile.BAK'. ---> WinSCP.SessionRemoteException: Copying files from remote side failed.
I really don't understand why it works manually everytime, that leads me to believe either a network hiccup or something with the remote side FTP server.
https://github.com/dotps1
SessionLog.txt (20.48 KB) Private file
Description: I will enabled debugging log as well if need be.
I've never seen this error before.
Did you read this?
http://serverfault.com/q/599081/168875
dotps1
Contributor
prikryl wrote:
I've never seem this error before.
Did you read this?
huh, ill reach out to the vendor and see if they have any AV on there system, the server I am using to run the task has not AV on it.
Thanks for the info, I will let you know what I find out.
dotps1
Contributor
Martin,
While I'm waiting on the vendor, is there a way to make the script retry the download on this error? I was thinking of doing like a while loop.
$result = $null
while ($result.Failures.Count -ne 0){
    $result = # Download file here.
but I was wondering if there is a built in way to handle this.
thanks.
dotps1
Contributor
Martin,
Is it possible to incorporate this from the client side?
http://trylinux.org/2007/12/14/vsftpd-426-failure-writing-network-stream/
or would this be something that has to happen on the server side?
dotps1 wrote:
Martin,
$result = $null
WinSCP retries only if the connection is lost while transferring. What is probably not this case.
Yes, that's a server-side setting.
