Topic "Progressbar update"
MrVinc
i upload files via SCP and want to see the status in a Progressbar.
How did i update the progressbar?
Here my Code for the upload with a backgroundworker:
 private void frm_main_Load(object sender, EventArgs e)
            worker = new BackgroundWorker();
            worker.WorkerReportsProgress = true;
            worker.WorkerSupportsCancellation = true;
            worker.DoWork += new DoWorkEventHandler(worker_DoWork);
        private void btn_hochladen_Click(object sender, EventArgs e)
            worker.RunWorkerAsync(2000);
        void worker_DoWork(object sender, DoWorkEventArgs e)
           if (arguments.Length > 1)
                for (int i = 1; i < arguments.Length; i++) // Loop through array
                        // Connect
                        session.Open(sessionOptions);
                        // Upload files
                        TransferOptions transferOptions = new TransferOptions();
                        transferOptions.TransferMode = TransferMode.Binary;
                        TransferOperationResult transferResult;
                        string path = "/recalbox/share/roms/" + folder + "/";
                        transferResult = session.PutFiles(@"" + String.Join(", ", arguments[i]), path, false, transferOptions);
                        //transferResult = session.PutFiles(@"" + String.Join(", ", arguments[i]), "/recalbox/share/test/", false, transferOptions);
                        // Throw on any error
                        transferResult.Check();
                        // Print results
                        //foreach (TransferEventArgs transfer in transferResult.Transfers)
                        //    MessageBox.Show(transfer.FileName);
Use Session.FileTransferProgress event:
https://winscp.net/eng/docs/library_session_filetransferprogress
