Topic "C# PARALLEL PROGRAMMING"
coriweb
we're using winscp .NET Assembly to download a very large directory of image files, and the download could take 6 hours for 6600 images (~1GB).
Is it possible to use the parallel programming paradigm to launch N session.GetFiles to obtain my files, but 4/5 at a time?
or the assembly could may not support parallel programming?
If the answer is yes, are there any samples?
thanks in advance
best regards
You have to use multiple instances of the Session, each running in its own thread
See http://winscp.net/eng/docs/library_example_parallel_transfers
(though the example is in PowerShell).
coriweb
Thank you, I'm gonna check your thread's link.
