Topic "Option to pick files in parallel under one folder"
I have started using WinSCP and I have been reading this forum. My requirement is to maximize the transfer rate by ftping as many parallel transfers as possible.
I did set the 'Maximum number of transfers at the same time:' to 9 (the max)
I also have chosen 'Transfer each file individually on background by default'
But when I select a large folder (having many sub folders and small files/large files in them), it does transfer it in single thread.
For testing, I had selected three files and drag/drop, it does go three threads.
How do I make sure my one large folder also uses the parallel option of selecting files within them and offering me the maximum throughput ?
Thanks for your post.
This issue is being tracked already:
