Topic "Sync does NOT follow folder symbolic links Linux -> Windows"
jcmanciot
WinSCP 5.7.6
Source Files: Ubuntu 15.10
Target Files: Windows 10
Uploaded screenshots:
- Symbolic links option is enabled
- Mirror sync mode
- no symbolic link ("Program-Files" here) is followed during sync
No automation tools have been used, only the GUI.
If I double-click on the symbolic link within the session panel, it is followed though, which means it is recognized as such by WinSCP.
No Symbolic Link is followed during sync.jpg (257.48 KB) [Download]
Description: No Symbolic Link is followed during sync
Sync Options.jpg (133.33 KB) [Download]
Description: Sync options
Symbolic Links Option.jpg (133.67 KB) [Download]
Description: Symbolic links option is enabled
jcmanciot
From the log which is attached:
Reading symlink "Program-Files".
Type: SSH_FXP_READLINK, Size: 56, Number: 1811
13,00,00,07,13,00,00,00,2F,2F,68,6F,6D,65,2F,61,63,74,69,6F,6E,6D,79,73,74,
69,71,75,65,2F,47,6F,6F,67,6C,65,20,44,72,69,76,65,2F,50,72,6F,67,72,61,6D,
2D,46,69,6C,65,73,
Sent 60 bytes
There are 0 bytes remaining in the send buffer
Link resolved to "/home/actionmystique/Program-Files".
Read 4 bytes (37 pending)
Read 37 bytes (0 pending)
Type: SSH_FXP_ATTRS, Size: 37, Number: 2065
69,00,00,08,11,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,03,E8,00,00,03,E8,
00,00,41,F8,56,B1,3E,48,56,D0,37,A4,
Read file 'Program-Files' from listing
Program-Files;D;0;2016-02-26T12:28:49.000Z;"actionmystique" [1000];"actionmystique" [1000];rwxrwxrwx;
The folder contains 347,796 items, totalling 27.0 GB.
root@172.17.100.1.log (3.98 MB) Private file
Description: Log file
Yes, the synchronization does not follow symbolic links.
We may add a support for optionally following the links, but it's not planned atm.
jcmanciot
Is the "Resolve symbolic links" option for syncing very different from reading ? I mean, when you know the whole contents of a symlinked folder, how different is it from what is already implemented to sync it?
It would be awesome to add this feature and shouldn't represent a lot more code.
It's not that it's difficult to follow the links.
It's that WinSCP explicitly skips the symlinks when synchronizing.
Most users want them to be skipped.
jcmanciot
Great, so adding the option could almost be done in a heartbeat Smile
This request is tracked here:
http://winscp.net/tracker/show_bug.cgi?id=51
jcmanciot
How can I be notified when the enhancement has been implemented?
jcmanciot
Brilliant! Smile
Almost perfect.
The symlinks are followed now during sync when the corresponding option is set.
However, I have isolated a very slight glitch so far: all date/time properties of synced files are correct, but for folders, they do not match; the date & time of the sync is used for the synced destination folders, instead of the date & time of the source folders.
WinSCP does not update timestamps of directories by default, no matter if it is symlinked directory or not.
You have to enable this. See:
https://winscp.net/eng/docs/ui_transfer_custom
jcmanciot
Well, despite the fact that WinSCP is run as administrator, some transfer options - including timestamps - are greyed out: cf. uploaded screenshots.
Am I missing something?
WinSCP as administrator.JPG (42.73 KB)
Description: WinSCP is run as administrator
Some WinSCP Transfer Options are greyed out.JPG (59.12 KB) [Download]
Description: Some WinSCP Transfer Options are greyed out
https://winscp.net/tracker/show_bug.cgi?id=1410
I'm sending you a new development version.
