Topic "How to execlude/compare files from synchronization?"
Samer
Hallo,
I would realy like someone to check the below command.
option batch abort
open sftp://----------------------------------------------------------------------------------------------
synchronize local -criteria=size C:\ /
I want to make an automated synchronization through TASK Schedular every 5 minutes only from the FTP Server to a local machine. The below are what I'm trying to achive(so far I only managed to do the first point -.-)
1- Download all File to the local machin.
2- If the files are already exist in the local machine, compare the size of both files and in case there is a differance, then download it from the FTP server to the local machin again.#
3- Execlude some files to be downloaded: for example: ( tmp, intern, and all ".DAV" directories)
Could someone preview the code and tell me how to add the 2nd and the 3rd point? I will be really be gratefull.
Thank you!
[/code]
You have the 2) already.
Regarding the 3):
Use the -filemask switch:
synchronize local -criteria=size -filemask="|tmp/;intern/;.DAV" C:\ /
See http://winscp.net/eng/docs/file_mask
Samer
Ty it's working perfectly.
