Topic "Advanced File Masks"
jonshipman
I've been struggling with this for a while so maybe someone can shed some light on this for me.
I'm working with a Magento install SO there are deep nested directories I need to sync to and from the server. I have been needing to open multiple WinSCP windows to sync, but figured I might use File Masks. Here is the mask I'm trying to do:
app/code/local/Companymodule/;
app/design/frontend/default/theme/;
app/design/frontend/default/mobile/;
skin/frontend/default/theme/;
skin/frontend/default/mobile/;
I don't want to sync the whole magento install, but just these folders and included files. All it does is sync the root files (skipping directories). If I add an * at the end, the whole server tries to sync. I'd appreciate some help in this whole masking business.
You cannot do it like this. You have exclude the directories, you do not want to synchronize, instead.
