Topic "error code: 5 after 2GB"
igor
Hi. I'm having problems downloading files larger than 2GB.
Protocol was SFTPv3. I did not try SCP because my connection is not that good and since it does not support resuming I had no other choice.
After copying 2GB I get following message.
Bad message (badly formatted packet or protocol incompatibility).
Error code: 5
Error message from server: Bad message
Request code: 5
I'm not quite sure what's the reason for this.
From your FAQ I've found out that SFTPv3 should be able of transfer larger than 4GB.
The file was in a SMB-mounted directory. Could it be there is something wrong with the Samba thing ?
Best,
Igor
I do not know where the problem can bem, sorry Sad WinSCP definitelly supports files over 2GB with SFTPv3. BTW, what version of WinSCP are you using?
igor
I've tried it with the latest and a few older versions of WinSCP... no luck. ok.. I'll try to find another way to get those files... thanks anyway.
I am having this same issue. Did anyone ever figure out a fix or problem?
Dragan
Does the problem occur with WinSCP 4.1.9 ?
I am having the same problem too. My version of WinSCP is 4.2.5.
Thanks.
Do you have the problem with other SFTP clients?
Also read FAQ.
