Topic "Maintain Folder Structure"
cnoffki
I have a local folder structure, from which I'm uploading files to a remote server using .Protocol = Protocol.Scp
I would like to maintain the local folder structure and just upload the files and delete them (the files, not the folders) when done.
I'm running a VB.NET console app, and my put files is the following :
transferResult = session.PutFiles("D:\remindererrors\", "remindererrors/", True, transferOptions)
I've tried several cominbinations of \, \* but it always seems to delete the local folders....Can anyone help with the correct syntax ?
Thanks !
There's no way to have WinSCP do this for you automatically.
You have to manually recurse the local tree and move the files one by one.
See this example http://winscp.net/eng/docs/library_example_recursive_download_custom_error_handling
(it's for download, not upload, but the principle is the same)
cnoffki
ok thank you !
